The Nabi Big Tab HD 24 has two internal speakers. When looking at the front of the tablet, there is one speaker located in each of the top corners. Before disassembly, determine which speaker is faulty. Mark which side the broken speaker is on by attaching a removable adhesive to the back panel.
Locate the four red rubber stops at the corners.
Use your fingers to carefully peel them off the device to reveal the screws underneath.
Use a Phillips #1 screwdriver to remove the 9.5 mm screw in each of the four corners.
Locate the the 4 small openings on the sides of the tablet.
Insert a metal spudger into one of the openings and carefully pop the device open by applying a steady downward force.
Repeat for the other three openings.
Use a plastic opening tool to carefully pry open the device from its hinges.
Locate the white port that connects the back panel to the circuit board on the back of the display.
Carefully pull the plastic connector straight out.
Carefully lift up the aluminum foil tape with your fingers so that the ribbon connector reveals itself.
Firmly press the two switches located on the sides of the connector and disconnect the connector from its connections.
Use a plastic opening tool and carefully push it underneath the grey plastic case surrounding the ribbon cable.
Apply a downward force to carefully peel the grey plastic off of the metal display.
Locate the two cables running on both sides of the device found at the bottom side of the screen.
Carefully grab both sides of the white plastic piece with your fingers and gently pull directly upward.
Locate the faulty speaker. The two speakers are located in the upper corners of the back panel.
Lift the speakers upwards, out of its holding place, with your fingers.
Follow the wires attached to the speakers to the motherboard.
Gently lift up the aluminum tape so you can see the white connector connecting the wires to the motherboard.
Pull the wire bundle out of the motherboard with a light tug to disconnect the speakers.
Replace your broken speaker with the new ones.
