There are four Nabi ports that are available to use. The Nabi ports are specific ports from Nabi that requires a USB adapter in order to connect a USB device to the tablet. Before replacing the Nabi port, determine which port is faulty, as there are four ports to choose from.
Locate the four red rubber stops at the corners.
Use your fingers to carefully peel them off the device to reveal the screws underneath.
Use a Phillips #1 screwdriver to remove the 9.5 mm screw in each of the four corners.
Locate the the 4 small openings on the sides of the tablet.
Insert a metal spudger into one of the openings and carefully pop the device open by applying a steady downward force.
Repeat for the other three openings.
Use a plastic opening tool to carefully pry open the device from its hinges.
Locate the white port that connects the back panel to the circuit board on the back of the display.
Carefully pull the plastic connector straight out.
Carefully lift up the aluminum foil tape with your fingers so that the ribbon connector reveals itself.
Firmly press the two switches located on the sides of the connector and disconnect the connector from its connections.
Use a plastic opening tool and carefully push it underneath the grey plastic case surrounding the ribbon cable.
Apply a downward force to carefully peel the grey plastic off of the metal display.
Locate the two cables running on both sides of the device found at the bottom side of the screen.
Carefully grab both sides of the white plastic piece with your fingers and gently pull directly upward.
Locate the nonfunctional Nabi port; there should be one on each side of the tablet.
Locate the black tab which secures the blue end of the ribbon cable to the Nabi port.
Lift up the black tab to release the ribbon cable.
Pull the ribbon connector away from the circuit board to disconnect it.
Unscrew the 4.5 mm silver screw holding the Nabi Port in place.
Lift out the Nabi Port and replace it with your new one.
