Nabi 2S Screen Replacement
  1. Nabi 2S Screen Replacement, Nabi 2S Disassembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the red rubber case from the device.
  2. Nabi 2S Screen Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nabi 2S Screen Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Make sure the screen is facing away from you and the back cover is facing you.
    • Using a Phillips #0 Screwdriver, unscrew the 3mm screws counter-clockwise in each corner of the plastic back cover. It will be a total of four screws. The smaller case on the back cover is attached to the main cover so it will not need to be removed.
  3. Nabi 2S Screen Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the plastic opening tool, remove the case.
    • Removing the case will take a bit of effort and force. We recommend using two hands and if possible another person to help. It will require some gusto.
    • It is helpful to pry at the corners first to loosen the case.
  4. Nabi 2S Screen Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • After the back case is loosened, remove it from the device to change or access the battery.
  5. Nabi 2S Screen Replacement, Screen: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nabi 2S Screen Replacement, Screen: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew the circuit board from the motherboard by using a Phillips #0 screwdriver to unscrew the 4mm screws in a counter-clockwise rotation.
  6. Nabi 2S Screen Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nabi 2S Screen Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nabi 2S Screen Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull motherboard away from the plastic.
    • Use hands to detach the screen because it is taped to the back of the motherboard.
    • Grip the screen and slide it out from between the plastic and the circuit board.
Riana Ramirez
crwdns2935283:003/07/16crwdne2935283:0
680 crwdns2915208:0crwdne2915208:0
Marist, Team 1-4, Laflen Spring 2016 crwdns2935289:0Marist, Team 1-4, Laflen Spring 2016crwdne2935289:0
MARS-LAFLEN-S16S1G4
crwdns2942667:0crwdne2942667:0 656
