Nabi 2 Charging Port Replacement
  1. Nabi 2 Charging Port Replacement, Nabi 2 Back Cover Removal: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nabi 2 Charging Port Replacement, Nabi 2 Back Cover Removal: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nabi 2 Charging Port Replacement, Nabi 2 Back Cover Removal: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the rubber bumper from the tablet.
  2. Nabi 2 Charging Port Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nabi 2 Charging Port Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • With a PH00 screwdriver, remove the four outermost screws from the back of the tablet.
  3. Nabi 2 Charging Port Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nabi 2 Charging Port Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nabi 2 Charging Port Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Carefully, insert a plastic opening tool into the seam of the device and begin gently prying the two plastic pieces apart.
    • Work the tool all the way around the device. Small plastic clips should release. If they do not, gently apply outwards pressure until the clips give.
    • Do not force the clips open, as they are fairly easy to break
  4. Nabi 2 Charging Port Replacement, Screen: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nabi 2 Charging Port Replacement, Screen: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nabi 2 Charging Port Replacement, Screen: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lay the tablet down flat and remove the yellow tape from the ZIF connector on each side
  5. Nabi 2 Charging Port Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nabi 2 Charging Port Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nabi 2 Charging Port Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using a spudger, slide the brown tab forward on each side of the connector
    • Slide until the connector is completely loose, then separate the screen from the bottom half of the tablet
    • If the screen is not working correctly, you will need to replace the entire display assembly
    que aser cuando no le pasa carga a la bateria
    yordenis sanchez - crwdns2934203:0crwdne2934203:0
    Where can I go to get a new screen
    Reis Brooks - crwdns2934203:0crwdne2934203:0
  6. Nabi 2 Charging Port Replacement, Battery: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nabi 2 Charging Port Replacement, Battery: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nabi 2 Charging Port Replacement, Battery: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the spudger to pop the battery out of place and set it aside.
  7. Nabi 2 Charging Port Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nabi 2 Charging Port Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nabi 2 Charging Port Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Desolder the battery connection and remove the battery completely
    • Note the color order for future replacemement
  8. Nabi 2 Charging Port Replacement, Internal Speakers: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the soldering iron, detach the speaker's wires from the circuit board.
  9. Nabi 2 Charging Port Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nabi 2 Charging Port Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nabi 2 Charging Port Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using a Phillips PH 000 screwdriver, unscrew the two 3 mm Phillips #000 screws on each side of the speakers that hold the speakers in place.
  10. Nabi 2 Charging Port Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once the screws have been removed, remove the speakers from the device.
  11. Nabi 2 Charging Port Replacement, Motherboard: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nabi 2 Charging Port Replacement, Motherboard: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the seven 4 mm Phillips #000 screws with a PH#000 screwdriver
  12. Nabi 2 Charging Port Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nabi 2 Charging Port Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nabi 2 Charging Port Replacement: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the tape that is attaching the motherboard to the plastic casing
  13. Nabi 2 Charging Port Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nabi 2 Charging Port Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nabi 2 Charging Port Replacement: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the motherboard by lifting from the area indicated
  14. Nabi 2 Charging Port Replacement, Charging Port: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nabi 2 Charging Port Replacement, Charging Port: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nabi 2 Charging Port Replacement, Charging Port: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using a soldering iron, desolder the charging port from the motherboard
    • Remove the charging port completely
    • If the glue does not completely detach from the board, try to heat it until the charging port can be removed
Trevor Westergard
crwdns2935283:002/10/16crwdne2935283:0
201 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 4-3, Lacy Spring 2016 crwdns2935289:0USF Tampa, Team 4-3, Lacy Spring 2016crwdne2935289:0
USFT-LACY-S16S4G3
crwdns2947412:07crwdne2947412:0
I think you would be better to just through it away and get something else.
Brad Cobb - crwdns2934203:0crwdne2934203:0
Naw they are still a handy fairly tough tablet for the kids shame about badly designed dc port I managed to find ports for it on ebay.
http://www.ebay.com/itm/dc-socket-port-j...
DotDotCom - crwdns2934203:0crwdne2934203:0
send me a new nabi in the mail today
Deborah Cramer - crwdns2934203:0crwdne2934203:0
A lot of unneeded work there. The power port is surface mount and and can be replaced without removing the PCB or anything else, but the back.
Donnie
Donnie - crwdns2934203:0crwdne2934203:0
Do steps 1-3 above then 4 desolder power port and clean area then reverse order.
Donnie
Bought a new battery and still wont turn on. but, wont charge. now what.
Sonya Harris - crwdns2934203:0crwdne2934203:0
Not to be a Ralph Repeater, but I agree with Donnie here, not sure why this article instructs you to take everything apart. That's just asking to get yourself into a major pickle, by tearing cables or losing small parts. Literally all you do is take off the rear, and it's right there, skip from the first set of photos to the very last photo. The author of this article is a real Johnny Overkill.
Also, can someone check on Deborah Cramer above, as I think she may be having a stroke. She has requested a replacement Nabi, from a unrelated repair site. I saw it in at least 3 different search results. What a goose!
Eli Bishop - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 35
crwdns2942667:0crwdne2942667:0 6,610
