Nabi 2 Screen Replacement
  1. Nabi 2  Screen Replacement, Nabi 2 Back Cover Removal: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nabi 2  Screen Replacement, Nabi 2 Back Cover Removal: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nabi 2  Screen Replacement, Nabi 2 Back Cover Removal: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the rubber bumper from the tablet.
  2. Nabi 2  Screen Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nabi 2  Screen Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • With a PH00 screwdriver, remove the four outermost screws from the back of the tablet.
  3. Nabi 2  Screen Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nabi 2  Screen Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nabi 2  Screen Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Carefully, insert a plastic opening tool into the seam of the device and begin gently prying the two plastic pieces apart.
    • Work the tool all the way around the device. Small plastic clips should release. If they do not, gently apply outwards pressure until the clips give.
    • Do not force the clips open, as they are fairly easy to break
  4. Nabi 2  Screen Replacement, Screen: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nabi 2  Screen Replacement, Screen: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nabi 2  Screen Replacement, Screen: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lay the tablet down flat and remove the yellow tape from the ZIF connector on each side
  5. Nabi 2  Screen Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nabi 2  Screen Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nabi 2  Screen Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using a spudger, slide the brown tab forward on each side of the connector
    • Slide until the connector is completely loose, then separate the screen from the bottom half of the tablet
    • If the screen is not working correctly, you will need to replace the entire display assembly
    que aser cuando no le pasa carga a la bateria
    yordenis sanchez - crwdns2934203:0crwdne2934203:0
    Where can I go to get a new screen
    Reis Brooks - crwdns2934203:0crwdne2934203:0
Michelle
crwdns2935283:002/09/16crwdne2935283:0
851 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 4-3, Lacy Spring 2016 crwdns2935289:0USF Tampa, Team 4-3, Lacy Spring 2016crwdne2935289:0
USFT-LACY-S16S4G3
Simple steps but very practical
myjamro - crwdns2934203:0crwdne2934203:0
Is the LCD glued to the front glass/digitizer?
Brent Huff - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 7,972
