crwdns2959928:0crwdne2959928:0 ↓Before beginning this guide we recommend following our Nabi 2 back cover removal guide.
This guide will walk you through the steps of replacing a cracked or otherwise non functioning screen on a Nabi 2. As the screen is glued to the front assembly, we recommend replacing the entire display assembly.
Be sure to use caution when releasing the clips that secure the display ribbon cables. Use a plastic spudger and push directly out, do not pry up on the clips, they will break.
Remove the rubber bumper from the tablet.
With a PH00 screwdriver, remove the four outermost screws from the back of the tablet.
Carefully, insert a plastic opening tool into the seam of the device and begin gently prying the two plastic pieces apart.
Work the tool all the way around the device. Small plastic clips should release. If they do not, gently apply outwards pressure until the clips give.
Lay the tablet down flat and remove the yellow tape from the ZIF connector on each side
Using a spudger, slide the brown tab forward on each side of the connector
Slide until the connector is completely loose, then separate the screen from the bottom half of the tablet
If the screen is not working correctly, you will need to replace the entire display assembly
Simple steps but very practical
myjamro - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Is the LCD glued to the front glass/digitizer?
Brent Huff - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
It Worked Thank U So Much!!!
Sharon Thrash - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
a piece that holds the screen ribbon cable in broke off my nabis motherboard while taking the screen off. I eventually did get the screen back on.
NabiGuy - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
