NVIDIA SHIELD Portable Motherboard Replacement
  1. NVIDIA SHIELD Portable Motherboard Replacement, Remove Front Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 NVIDIA SHIELD Portable Motherboard Replacement, Remove Front Panel: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 NVIDIA SHIELD Portable Motherboard Replacement, Remove Front Panel: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the seven 6.4mm T5 Torx screws from the back panel.
    • Use the spudger to separate the front and back panels.
  2. NVIDIA SHIELD Portable Motherboard Replacement, Remove Green Grill: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 NVIDIA SHIELD Portable Motherboard Replacement, Remove Green Grill: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The green grill is not screwed in so it can be pulled right out.
  3. NVIDIA SHIELD Portable Motherboard Replacement, Remove Battery Cables: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 NVIDIA SHIELD Portable Motherboard Replacement, Remove Battery Cables: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 NVIDIA SHIELD Portable Motherboard Replacement, Remove Battery Cables: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the six 6.5mm T5 Torx screws.
    • Disconnect the power wires.
    • Peel back the copper tape and disconnect the black and white wires.
  4. NVIDIA SHIELD Portable Motherboard Replacement, Remove Battery Apparatus: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the battery apparatus out once all cables are removed.
  5. NVIDIA SHIELD Portable Motherboard Replacement, Removing Fan: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 NVIDIA SHIELD Portable Motherboard Replacement, Removing Fan: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 NVIDIA SHIELD Portable Motherboard Replacement, Removing Fan: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Cooling is important for electronics, the last thing they want is to overheat.
    • Remove the two 7.3mm and four 8.4mm T5 Torx screws and disconnect the power cable.
    • Lift the fan free after the screws and cable are removed.
  6. NVIDIA SHIELD Portable Motherboard Replacement, Removing Logic Board: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 NVIDIA SHIELD Portable Motherboard Replacement, Removing Logic Board: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 NVIDIA SHIELD Portable Motherboard Replacement, Removing Logic Board: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The large board under the back case is the motherboard.
    • Using your T5 Torx screwdriver, remove six screws from the motherboard—two 7.3 mm screws and four 8.4 mm screws.
    • Simply pull gently on the edges of the board, wiggling it if necessary so as not to damage the ports at the top of the board.
Marc Perez
crwdns2935283:009/29/14crwdne2935283:0
545 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 1-1, Hickman Fall 2014 crwdns2935289:0USF Tampa, Team 1-1, Hickman Fall 2014crwdne2935289:0
USFT-HICKMAN-F14S1G1
crwdns2935297:018crwdne2935297:0
Hay ich suche Ersatzteile für Nvidia shield Portable ich suche Board da wo kühler drauf ist , weil mein ist kaput gegangen :(
Konstantin Styngu - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 2,084
