NVIDIA GeForce GTX 970 GPU Replacement
  1. NVIDIA GeForce GTX 970 GPU Replacement, GPU: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 NVIDIA GeForce GTX 970 GPU Replacement, GPU: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unplug all the external cables from the computer and ensure that the power supply is switched off.
  2. NVIDIA GeForce GTX 970 GPU Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 NVIDIA GeForce GTX 970 GPU Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the case side panel by applying pressure to the side and sliding the side panel toward the back of the case.
    • Some cases may have screws that must be removed or tabs that must be pressed before the siding will slide off.
  3. NVIDIA GeForce GTX 970 GPU Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 NVIDIA GeForce GTX 970 GPU Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 NVIDIA GeForce GTX 970 GPU Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pinch the lock at the end of the GPU power cable and carefully disconnect it.
  4. NVIDIA GeForce GTX 970 GPU Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 NVIDIA GeForce GTX 970 GPU Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 NVIDIA GeForce GTX 970 GPU Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the two Philips #1 mounting screws that attach the GPU to the inside of the case.
  5. NVIDIA GeForce GTX 970 GPU Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 NVIDIA GeForce GTX 970 GPU Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 NVIDIA GeForce GTX 970 GPU Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Press down the locking tab at the base of the GPU.
  6. NVIDIA GeForce GTX 970 GPU Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the GPU from the case. If it does not move, check to make sure that steps 3-5 were properly performed.
  7. NVIDIA GeForce GTX 970 GPU Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 NVIDIA GeForce GTX 970 GPU Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • When inserting a replacement GPU, ensure that the base is lined up properly with the appropriate slot on the motherboard.
    • Once the replacement GPU is lined up, press down until you hear a click or can see that the locking tab is flipped up again.
To finish reassembly, follow steps 2-4 in reverse order.
crwdns2935229:011crwdne2935229:0
Nicholas Eichman
crwdns2935283:003/22/21crwdne2935283:0
415 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team S3-G7, Saloman Spring 2021 crwdns2935289:0UMass Dartmouth, Team S3-G7, Saloman Spring 2021crwdne2935289:0
UMASSD-SALOMAN-S21S3G7
crwdns2936753:030crwdne2936753:0 82
crwdns2942667:0crwdne2942667:0 7,940
