crwdns2959928:0crwdne2959928:0 ↓Are your keys malfunctioning or not registering correctly"? Consider using this guide to replace the keyboard of your laptop.
Flip the laptop over so that the bottom of the laptop is facing upwards.
Remove securing screw with the PH0 head.
Slide the optical drive out and remove it from the device.
Remove the two Phillips #0 screws labeled KBD.
There are 5 clips along the top of the keyboard. Insert a thin opener tool (iSessamo tool or similar) between each clip and the keyboard tray to release it.
Do not bend your keyboard as shown in this picture.
Lift the keyboard up to release catches on the sides, then slide the keyboard towards the screen to slide tabs out of the slots at the bottom.
Disconnect the keyboard cable from the motherboard.
