NIkon Coolpix A900 Lens Replacement
  1. NIkon Coolpix A900 Lens Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Orient the camera so that it is upside down, with the lens facing towards you.
  2. NIkon Coolpix A900 Lens Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 NIkon Coolpix A900 Lens Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the battery door lock left to unlock it.
    • The battery door will automatically open.
    Good addition of different conditions of the camera (camera is dirty)
    Brandon - crwdns2934203:0crwdne2934203:0
  3. NIkon Coolpix A900 Lens Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 NIkon Coolpix A900 Lens Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the yellow tab up to release the battery.
    • To re-insert a battery, slide the battery back in until the yellow tab locks it in place.
    • There is a diagram on the opposite side of the battery compartment to help you orient the battery correctly.
  4. NIkon Coolpix A900 Lens Replacement, Rear Case: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 NIkon Coolpix A900 Lens Replacement, Rear Case: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 NIkon Coolpix A900 Lens Replacement, Rear Case: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Orient the camera upside down, with the lens facing away from you.
    • Remove the two 3mm Phillips #00 screws from the right.
    • Remove the two 3.4mm Phillips #00 screws from the left.
  5. NIkon Coolpix A900 Lens Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 NIkon Coolpix A900 Lens Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 NIkon Coolpix A900 Lens Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Turn the camera on its side, with the lens facing away from you.
    • Remove the 3.4mm Phillips #00 screw. Repeat this for the opposite side of the camera.
  6. NIkon Coolpix A900 Lens Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 NIkon Coolpix A900 Lens Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 NIkon Coolpix A900 Lens Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Place the camera upright with the lens facing away from you.
    • Move the monitor down, and remove two 4.4 mm screws.
    After dropping the camera image with small apertures appears
    D.Osei - crwdns2934203:0crwdne2934203:0
  7. NIkon Coolpix A900 Lens Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 NIkon Coolpix A900 Lens Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two black 2.5 mm screws from the monitor bracket.
    Is there anywhere I can buy a replacement screw for this part? I have lost one of these screws
    Dylan Feeney - crwdns2934203:0crwdne2934203:0
  8. NIkon Coolpix A900 Lens Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 NIkon Coolpix A900 Lens Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Return the monitor to the closed position.
    • Gently open the rear case.
    • You may need opening tools to help separate the rear case.
    • Be careful when opening the rear case to not damage the ribbon connectors.
  9. NIkon Coolpix A900 Lens Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 NIkon Coolpix A900 Lens Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 NIkon Coolpix A900 Lens Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Place the camera lens down, while supporting the rear case.
    • Unlock the two ribbons by using your finger to lift the plastic hinge on the ribbon connector.
    • With the ribbons disconnected, you can now remove the rear case.
  10. NIkon Coolpix A900 Lens Replacement, Lens: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 NIkon Coolpix A900 Lens Replacement, Lens: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 NIkon Coolpix A900 Lens Replacement, Lens: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Place the camera in front of you with the lens facing down.
    • On the top right, remove the 4.5 mm Phillips #00 screw holding the input shield.
  11. NIkon Coolpix A900 Lens Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 NIkon Coolpix A900 Lens Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the 4.5 mm Phillips #00 screw holding the bracket in the bottom right.
    • Remove the 2.5 mm Phillips #00 rear brace screw.
  12. NIkon Coolpix A900 Lens Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 NIkon Coolpix A900 Lens Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 NIkon Coolpix A900 Lens Replacement: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use your finger to undo the ribbon connector on the top right of the camera.
    • Remove the two 2.5mm Phillips #00 screws holding the small chip in place. Remove the small chip.
    • Remove the final two 4.5 mm Phillips #00 screws from the left side of the brace.
  13. NIkon Coolpix A900 Lens Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 NIkon Coolpix A900 Lens Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently lift the rear brace off of the camera.
  14. NIkon Coolpix A900 Lens Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 NIkon Coolpix A900 Lens Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your finger to undo the three ribbon connectors.
    • Make sure that all ribbons are properly disconnected before proceeding.
  15. NIkon Coolpix A900 Lens Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 NIkon Coolpix A900 Lens Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 NIkon Coolpix A900 Lens Replacement: crwdns2935265:015crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Carefully lift the lens out of the camera.
    • It may be necessary to gently pry these tabs out of the way to release the lens.
    • When reassembling, make sure that the ribbon cables are flat against the lens to ensure that they don't snag.
  16. NIkon Coolpix A900 Lens Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Separate the lens from the body of the camera.
    I disassembled the zoom lens so I could remove the dust behind the glass. It is possible but both disassembly and reassembly takes a lot of patience and instinct.
    Hanspeter Doswald - crwdns2934203:0crwdne2934203:0
    Mijn lens unit is geblokkeerd, is dat te verhelpen?
    Ad de Jong - crwdns2934203:0crwdne2934203:0
Andres Aronstam
crwdns2935283:009/17/19crwdne2935283:0
780 crwdns2915208:0crwdne2915208:0
Embry-Riddle Aeronautical University, Team S22-G3, Branham Fall 2019 crwdns2935289:0Embry-Riddle Aeronautical University, Team S22-G3, Branham Fall 2019crwdne2935289:0
ERAU-BRANHAM-F19S22G3
How to replace the front-lens of the zoom-lens, when it’s scratched!?!
Tom de Hoop - crwdns2934203:0crwdne2934203:0
Ok I removed the defective one, but my question now is: what model of lens can I replace it with? Is it compatible with any lens from Nikon, or from other manufacturers?
martin - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 22
crwdns2936753:030crwdne2936753:0 100
crwdns2942667:0crwdne2942667:0 4,394
