NETGEAR WGT624 v3 Capacitor Replacement
Jonathon Sather
crwdns2944107:0crwdnd2944107:0Jonathon Sathercrwdnd2944107:0crwdnd2944107:0crwdnd2944107:04crwdnd2944107:0crwdne2944107:0
crwdns2944111:0Yan 4, 2023crwdne2944111:0
crwdns2931287:015crwdne2931287:0
crwdns2937801:0crwdne2937801:0
crwdns2862591:0crwdne2862591:0
crwdns2942287:0crwdne2942287:0
This guide will demonstrate how to remove the capacitors in order to replace them. Soldering and de-soldering will be required.
crwdns2944105:0crwdne2944105:0
  1. NETGEAR WGT624 v3 Capacitor Replacement, Lower Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn the device so that the bottom is facing up.
  2. NETGEAR WGT624 v3 Capacitor Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 NETGEAR WGT624 v3 Capacitor Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 NETGEAR WGT624 v3 Capacitor Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the plastic opening tool to carefully lift the rubber stops in each corner.
    • Do not completely remove the rubber stops, because they are difficult to replace.
  3. NETGEAR WGT624 v3 Capacitor Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 NETGEAR WGT624 v3 Capacitor Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew the 4 11.8 mm T-8 Torx screws from each corner of the device.
  4. NETGEAR WGT624 v3 Capacitor Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 NETGEAR WGT624 v3 Capacitor Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the lower case straight up from the rest of the router.
  5. NETGEAR WGT624 v3 Capacitor Replacement, Motherboard: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 NETGEAR WGT624 v3 Capacitor Replacement, Motherboard: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the clear plastic casing by lifting it straight up from the router.
  6. NETGEAR WGT624 v3 Capacitor Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 NETGEAR WGT624 v3 Capacitor Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Separate the motherboard from the top shell by lifting it straight up from the router.
  7. NETGEAR WGT624 v3 Capacitor Replacement, Capacitor: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn the motherboard so that the top is facing upwards.
    • Place the motherboard on a clean flat surface.
  8. NETGEAR WGT624 v3 Capacitor Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate the four capacitors.
  9. NETGEAR WGT624 v3 Capacitor Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 NETGEAR WGT624 v3 Capacitor Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Turn the motherboard so that the bottom is facing upwards.
    • Locate the two soldered contacts for each capacitor.
  10. NETGEAR WGT624 v3 Capacitor Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 NETGEAR WGT624 v3 Capacitor Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Do not refer to the pictures in this step for correct soldering and de-soldering techniques. They are solely for illustration purposes.
    • Desolder the soldered connections between the capacitors and the motherboard, and pull the capacitor from the motherboard.
    • For proper soldering and de-soldering techniques, refer here.
    • When reinstalling the capacitor, make sure the negative side of the capacitor is aligned with the shaded white region of the circle.
Jonathon Sather
crwdns2935283:001/23/13crwdne2935283:0
45 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 3-31, Amido Winter 2013 crwdns2935289:0Cal Poly, Team 3-31, Amido Winter 2013crwdne2935289:0
CPSU-AMIDO-W13S3G31
my router NETGEAR WNR 612 WIFI LED NOT GLOWING PLEASE HLP ME IN REPAIRING
Vinod Kumar Polakonda - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 9
crwdns2942667:0crwdne2942667:0 1,582
