NABI XD Screen Replacement
    1. NABI XD Screen Replacement, Rear panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 NABI XD Screen Replacement, Rear panel: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use the plastic opening tool at the top left corner seam, then pry the corner apart.
    2. NABI XD Screen Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Next slide the plastic opening tool across the sides of the Nabi. It will slowly open.
      • There are small plastic clips that need to be release. Gently apply outwards pressure until the clips give.
      • Go around the NABI XD and separate the rear panel from the device.
    1. NABI XD Screen Replacement, Battery: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 NABI XD Screen Replacement, Battery: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Place your fingernails on both sides of the connector and pull it straight back away from the holder.
    2. NABI XD Screen Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Battery is glued to the base, lift carefully.
      • To remove battery, lift the battery up from the motherboard.
    1. NABI XD Screen Replacement, Charging port: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 NABI XD Screen Replacement, Charging port: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the two 4mm Phillips screws with the PH#0 screwdriver.
      • Disconnect the left (L) speaker wire from the charging port by grabbing it on both sides with the tweezers and pulling straight back.
    2. NABI XD Screen Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use your fingernails or a spudger to flip up the small retaining flap, then pull the ribbon straight back to remove
      • Lift the charging port from the NABI XD.
    1. NABI XD Screen Replacement, Motherboard: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 NABI XD Screen Replacement, Motherboard: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 NABI XD Screen Replacement, Motherboard: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • To remove the marked ribbons, use your fingernails or a spudger to lift up small tab
      • Use the Precision Tweezers to gently pull the ribbons straight out of the connectors.
      • You need to remove 4 ribbons
    2. NABI XD Screen Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 NABI XD Screen Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 NABI XD Screen Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Disconnect the camera by lifting the ribbon straight up. Also disconnect the remaining ribbon by lifting up gently.
      • To disconnect antenna wire, use the tweezers to pry connector straight from the board.
    3. NABI XD Screen Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 NABI XD Screen Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Disconnect the Right speaker by grabbing the wire head by its sides and pulling it back from the connector.
    4. NABI XD Screen Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 NABI XD Screen Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the four 4mm Phillips screws with the PH#0 screwdriver.
    5. NABI XD Screen Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Lift the motherboard up away from the Nabi XD.
    1. NABI XD Screen Replacement, Speakers: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 NABI XD Screen Replacement, Speakers: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 NABI XD Screen Replacement, Speakers: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Right (R) speaker removal:
      • Remove one 4mm Phillips screw.
      • Use the metal spudger to separate the speaker from the frame.
      • The speaker is glued to the Nabi XD it will require some force to separate them.
    2. NABI XD Screen Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 NABI XD Screen Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the left (L) speaker wire from the frame by pulling it to the side and up.
      • The wire in this step, is connected to the charging port. Removing it, is shown in detail on step 6.
    3. NABI XD Screen Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 NABI XD Screen Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 NABI XD Screen Replacement: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Left (L) speaker removal:
      • Remove two 4mm Phillips screws.
    1. NABI XD Screen Replacement, Screen: crwdns2935265:015crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 NABI XD Screen Replacement, Screen: crwdns2935265:015crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 NABI XD Screen Replacement, Screen: crwdns2935265:015crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • The ribbons are glued to the frame so gently lift them up without ripping them.
      • Lightly lift the marked wires and ribbons from the frame by gently pulling them in the direction of the arrows and up.
      • Remove five 4mm Phillips screws from the frame.
    2. NABI XD Screen Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 NABI XD Screen Replacement: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use the Plastic Opening tools to lift the frame up.
      • The ribbons need to be detangled from the frame while you are lifting it up.
      • Do not yank the frame away from the Nabi XD it is connect to it by a ribbon. Gently lift.
    3. NABI XD Screen Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 NABI XD Screen Replacement: crwdns2935265:017crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Lift the screen up with the black spudger.
      • Lift the frame up slowly and place it to the side.
Marissa Schiereck
crwdns2935283:009/15/16crwdne2935283:0
638 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 17-2, Blackwell Fall 2016 crwdns2935289:0USF Tampa, Team 17-2, Blackwell Fall 2016crwdne2935289:0
USFT-BLACKWELL-F16S17G2
Will the screen from an A or C model work with a B model?
Kevin Fifer - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:030crwdne2936753:0 92
crwdns2942667:0crwdne2942667:0 1,224
