NABI XD Charging port Replacement
  1. NABI XD Charging port Replacement, Rear panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 NABI XD Charging port Replacement, Rear panel: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the plastic opening tool at the top left corner seam, then pry the corner apart.
  2. NABI XD Charging port Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Next slide the plastic opening tool across the sides of the Nabi. It will slowly open.
    • There are small plastic clips that need to be release. Gently apply outwards pressure until the clips give.
    • Go around the NABI XD and separate the rear panel from the device.
  3. NABI XD Charging port Replacement, Battery: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 NABI XD Charging port Replacement, Battery: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Place your fingernails on both sides of the connector and pull it straight back away from the holder.
  4. NABI XD Charging port Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Battery is glued to the base, lift carefully.
    • To remove battery, lift the battery up from the motherboard.
  5. NABI XD Charging port Replacement, Charging port: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 NABI XD Charging port Replacement, Charging port: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two 4mm Phillips screws with the PH#0 screwdriver.
    • Disconnect the left (L) speaker wire from the charging port by grabbing it on both sides with the tweezers and pulling straight back.
  6. NABI XD Charging port Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use your fingernails or a spudger to flip up the small retaining flap, then pull the ribbon straight back to remove
    • Lift the charging port from the NABI XD.
Marissa Schiereck
crwdns2935283:009/15/16crwdne2935283:0
638 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 17-2, Blackwell Fall 2016 crwdns2935289:0USF Tampa, Team 17-2, Blackwell Fall 2016crwdne2935289:0
USFT-BLACKWELL-F16S17G2
crwdns2936753:030crwdne2936753:0 66
crwdns2942667:0crwdne2942667:0 872
