Munchkinz Volume Button assembly
  1. Munchkinz Volume Button assembly, Opening Device: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Insert spudger into the USB Micro slot and pry the case apart.
    • Be careful not to go too deep and bend the prong inside the Micro USB port.
  2. Munchkinz Volume Button assembly, Pry Device Apart: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Munchkinz Volume Button assembly, Pry Device Apart: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the wide plastic opening tool across the seem, separating it if you can't pry the device open using just the spudger.
    • Gently separate the case so none of the cords inside are disconnected
  3. Munchkinz Volume Button assembly, Separated Device: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • After prying the device apart, it should look like this.
  4. Munchkinz Volume Button assembly, Pry Camera: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the slim plastic opening tool to pry the camera from its initial position.
  5. Munchkinz Volume Button assembly, Disconnect Ribbon: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the precision tweezers to gently disconnect the camera ribbon that is connected to the motherboard.
  6. Munchkinz Volume Button assembly, Volume Button: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the plastic volume button.
  7. Munchkinz Volume Button assembly, Unscrew Module: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two screws that hold the volume button assembly in place.
  8. Munchkinz Volume Button assembly, Solder Module Wires: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Un-solder the yellow, red, and black wires that connect the volume module to the motherboard.
David Wood
crwdns2935283:002/05/15crwdne2935283:0
440 crwdns2915208:0crwdne2915208:0
UW Tacoma, Team 3-6, Rose Winter 2015 crwdns2935289:0UW Tacoma, Team 3-6, Rose Winter 2015crwdne2935289:0
UWT-ROSE-W15S3G6
crwdns2942667:0crwdne2942667:0 336
