Munchkinz Motherboard Replacement
  1. Munchkinz Motherboard Replacement, Opening Device: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Insert spudger into the USB Micro slot and pry the case apart.
    • Be careful not to go too deep and bend the prong inside the Micro USB port.
  2. Munchkinz Motherboard Replacement, Pry Device Apart: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Munchkinz Motherboard Replacement, Pry Device Apart: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the wide plastic opening tool across the seem, separating it if you can't pry the device open using just the spudger.
    • Gently separate the case so none of the cords inside are disconnected
  3. Munchkinz Motherboard Replacement, Separated Device: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • After prying the device apart, it should look like this.
  4. Munchkinz Motherboard Replacement, Pry Camera: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the slim plastic opening tool to pry the camera from its initial position.
  5. Munchkinz Motherboard Replacement, Disconnect Ribbon: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the precision tweezers to gently disconnect the camera ribbon that is connected to the motherboard.
  6. Munchkinz Motherboard Replacement, Pry Speaker: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Munchkinz Motherboard Replacement, Pry Speaker: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the slim plastic opening tool to remove the speaker from its position on the case.
  7. Munchkinz Motherboard Replacement, Locate Wires: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate the red and black wires that connect the speaker to the motherboard.
  8. Munchkinz Motherboard Replacement, Solder Wires: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Un-solder the red and black speaker wires that are connected to the motherboard
  9. Munchkinz Motherboard Replacement, Volume Button: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the plastic volume button.
  10. Munchkinz Motherboard Replacement, Unscrew Module: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two screws that hold the volume button assembly in place.
  11. Munchkinz Motherboard Replacement, Solder Module Wires: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Un-solder the yellow, red, and black wires that connect the volume module to the motherboard.
  12. Munchkinz Motherboard Replacement, Removing battery: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Munchkinz Motherboard Replacement, Removing battery: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Munchkinz Motherboard Replacement, Removing battery: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the wide plastic opening tool to slowly pry each side of the battery up.
    • Be careful not to bend the battery too much.
  13. Munchkinz Motherboard Replacement, Remove battery completely: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the Soldering Iron to disconnect the each cable.
  14. Munchkinz Motherboard Replacement, Remove Tape: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove black tape covering any of the ribbons that have it.
  15. Munchkinz Motherboard Replacement, Remove Ribbons: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the ribbons out from the plugs.
  16. Munchkinz Motherboard Replacement, Remove Camera/Hidden Screw: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • After removing the camera, remove the hidden screw.
  17. Munchkinz Motherboard Replacement, Remove Screws: crwdns2935265:017crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove screws located on the opposite side of the battery.
  18. Munchkinz Motherboard Replacement, Lift: crwdns2935265:018crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully lift up the motherboard. Your accessory parts such as battery, speaker, volume button assembly, and camera wires will be disconnected, not connected, like in this picture.
Austin Oliveira
crwdns2935283:002/05/15crwdne2935283:0
204 crwdns2915208:0crwdne2915208:0
UW Tacoma, Team 3-6, Rose Winter 2015 crwdns2935289:0UW Tacoma, Team 3-6, Rose Winter 2015crwdne2935289:0
UWT-ROSE-W15S3G6
crwdns2936753:030crwdne2936753:0 4
crwdns2942667:0crwdne2942667:0 316
