Munchkinz LCD Assembly
David Wood
crwdns2944107:0crwdnd2944107:0David Woodcrwdnd2944107:0crwdnd2944107:0crwdnd2944107:03crwdnd2944107:0crwdne2944107:0
crwdns2944111:0May 13, 2019crwdne2944111:0
crwdns2931287:025crwdne2931287:0
crwdns2937801:0crwdne2937801:0
crwdns2942287:0crwdne2942287:0
If your screen is not working properly follow this guide to replace it.
  • Spudger
    Spudger
  • iFixit Opening Tool
    iFixit Opening Tool
crwdns2944105:0crwdne2944105:0
  1. Munchkinz LCD Assembly, Opening Device: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Insert spudger into the USB Micro slot and pry the case apart.
    • Be careful not to go too deep and bend the prong inside the Micro USB port.
  2. Munchkinz LCD Assembly, Pry Device Apart: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Munchkinz LCD Assembly, Pry Device Apart: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the wide plastic opening tool across the seem, separating it if you can't pry the device open using just the spudger.
    • Gently separate the case so none of the cords inside are disconnected
  3. Munchkinz LCD Assembly, Separated Device: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • After prying the device apart, it should look like this.
  4. Munchkinz LCD Assembly, Remove Speaker: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the plastic opening tool to remove the speaker from the casing.
  5. Munchkinz LCD Assembly, Pry Camera: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the slim plastic opening tool to pry the camera from its position.
  6. Munchkinz LCD Assembly, Unscrew Volume Module: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Munchkinz LCD Assembly, Unscrew Volume Module: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew the two screws that hold the volume module to the casing.
  7. Munchkinz LCD Assembly, Pry Battery: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the plastic opening tool to slowly pry each side of the battery up.
    • Be careful not to bend the battery too much.
  8. Munchkinz LCD Assembly, Remove Ribbons: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two highlighted ribbons from the motherboard.
  9. Munchkinz LCD Assembly, Remove Screws: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the screw driver to remove the highlighted screws.
  10. Munchkinz LCD Assembly, Remove Hidden Screw: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the plastic opening tool to hold the camera ribbon back.
    • Unscrew the screw under ribbon with the screw driver.
  11. Munchkinz LCD Assembly, Remove Motherboard: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the motherboard from the casing.
  12. Munchkinz LCD Assembly, Pry Up Screen: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Munchkinz LCD Assembly, Pry Up Screen: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Munchkinz LCD Assembly, Pry Up Screen: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Oriented the device so the battery is closest to the user.
    • Use the plastic opening tool to pry the clips up to release LCD screen.
    • Gently lift the northern end of the screen and slide it out horizontally.
  13. Munchkinz LCD Assembly, Solder LCD Wires: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unsolder the black and red LCD wires.
David Wood
crwdns2935283:002/05/15crwdne2935283:0
440 crwdns2915208:0crwdne2915208:0
UW Tacoma, Team 3-6, Rose Winter 2015 crwdns2935289:0UW Tacoma, Team 3-6, Rose Winter 2015crwdne2935289:0
UWT-ROSE-W15S3G6
crwdns2942667:0crwdne2942667:0 387
