Munchkinz Battery Replacement
crwdns2869540:0crwdne2869540:0: 991
3
18
82
991
crwdns2959984:0crwdne2959984:0: 0
crwdns2959956:0crwdne2959956:0
crwdns2955944:0crwdne2955944:0: 5 - 10 crwdns2931279:0crwdne2931279:0
Display how to remove the battery.
    1. Munchkinz Battery Replacement, Opening Device: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Insert spudger into the USB Micro slot and pry the case apart.
      • Be careful not to go too deep and bend the prong inside the Micro USB port.
    2. Munchkinz Battery Replacement, Pry Device Apart: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Munchkinz Battery Replacement, Pry Device Apart: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Slide the wide plastic opening tool across the seem, separating it if you can't pry the device open using just the spudger.
      • Gently separate the case so none of the cords inside are disconnected
    3. Munchkinz Battery Replacement, Separated Device: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • After prying the device apart, it should look like this.
    1. Munchkinz Battery Replacement, Removing battery: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Munchkinz Battery Replacement, Removing battery: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Munchkinz Battery Replacement, Removing battery: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Use the wide plastic opening tool to slowly pry each side of the battery up.
      • Be careful not to bend the battery too much.
    2. Munchkinz Battery Replacement, Remove battery completely: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use the Soldering Iron to disconnect the each cable.
Hee Jin Cho
crwdns2935283:001/14/15crwdne2935283:0
113 crwdns2915208:0crwdne2915208:0
UW Tacoma, Team 3-6, Rose Winter 2015 crwdns2935289:0UW Tacoma, Team 3-6, Rose Winter 2015crwdne2935289:0
UWT-ROSE-W15S3G6
crwdns2935297:084crwdne2935297:0
crwdns2936753:07crwdne2936753:0 18
crwdns2936753:030crwdne2936753:0 82
crwdns2959996:0crwdne2959996:0 991
