Only replace speaker as a last measure, since getting to the speaker requires removal of parts that might not fit perfectly back together.
Remove two 6 mm Phillips #2 screws on either side of the On/Off Plate.
Remove the On/Off switch plate and save the screws so you can use them later to put the plate back on.
Gently pull out the battery cartridge and if needed, replace the batteries with 3 AA alkaline batteries.
Starting with the yellow face, insert the metal spudger between the yellow face and the white frame, prying the frame apart.
Insert the metal spudger in the space created by the plastic opening tool between the frame and face of the cube.
Pry the cube face from the frame.
After removing the square plates, you can unscrew the screws underneath.
Remove four 6 mm Phillips #2 screws, located on the sides.
Remove the rubber corners by simply pulling them off.
Remove twenty-four 6 mm Phillips #2 from all 6 sides.
Once the screws are removed, gently pull apart the frame.
Remove four 6 mm Phillips #2 screws that hold down the speaker to its plastic frame.
Remove two 6 mm Phillips #2 screws holding down the main motherboard to plastic frame.
Gently remove speaker and motherboard from plastic frame.
Desolder speaker cable connections from the motherboard.
