Munchkin Mozart Magic Cube Light Replacement
  1. Munchkin Mozart Magic Cube Light Replacement, Face plate: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Munchkin Mozart Magic Cube Light Replacement, Face plate: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove two 6 mm Phillips #2 screws on either side of the On/Off Plate.
  2. Munchkin Mozart Magic Cube Light Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the On/Off switch plate and save the screws so you can use them later to put the plate back on.
  3. Munchkin Mozart Magic Cube Light Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently pull out the battery cartridge and if needed, replace the batteries with 3 AA alkaline batteries.
  4. Munchkin Mozart Magic Cube Light Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Starting with the yellow face, insert the metal spudger between the yellow face and the white frame, prying the frame apart.
  5. Munchkin Mozart Magic Cube Light Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Insert the metal spudger in the space created by the plastic opening tool between the frame and face of the cube.
    • Pry the cube face from the frame.
  6. Munchkin Mozart Magic Cube Light Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • After removing the square plates, you can unscrew the screws underneath.
    • Remove four 6 mm Phillips #2 screws, located on the sides.
  7. Munchkin Mozart Magic Cube Light Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the rubber corners by simply pulling them off.
  8. Munchkin Mozart Magic Cube Light Replacement, Frame Removal: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove twenty-four 6 mm Phillips #2 from all 6 sides.
    • Once the screws are removed, gently pull apart the frame.
  9. Munchkin Mozart Magic Cube Light Replacement, Light: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the frame over so that green motherboard over so that the LED is face down and the brown side of the motherboard is face up.
    • Use the Jimmy to remove the glue connecting the motherboard to the white frame.
  10. Munchkin Mozart Magic Cube Light Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide the motherboard out of the frame.
  11. Munchkin Mozart Magic Cube Light Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the soldering iron to desolder the LED by applying heat to the half sphere like connections.
    • For soldering instructions please see this additional guide How To Solder and Desolder Connections
  12. Munchkin Mozart Magic Cube Light Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Take the new LED and solder the two legs back to the motherboard.
Nikolas Soulandros
crwdns2935283:008/27/15crwdne2935283:0
291 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 1-4, Sullivan Fall 2015 crwdns2935289:0USF Tampa, Team 1-4, Sullivan Fall 2015crwdne2935289:0
USFT-SULLIVAN-F15S1G4
crwdns2942667:0crwdne2942667:0 616
