Mr. Coffee DW13 Heating Plate Replacement
  1. Mr. Coffee DW13 Heating Plate Replacement, Base: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Mr. Coffee DW13 Heating Plate Replacement, Base: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Before performing this repair, be sure that your machine is unplugged and dry and that your work space is clean.
    • Flip the Mr. Coffee DW13 over so that the lid is facing away from you and the base is facing toward you.
  2. Mr. Coffee DW13 Heating Plate Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Mr. Coffee DW13 Heating Plate Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the eight 11 mm screws that secure the base of the machine with a Phillips Head #2 screwdriver.
  3. Mr. Coffee DW13 Heating Plate Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently lift the base cover to expose the inside of the coffee machine.
    SO interesting! I love fixing things, myself. Many things are so
    easy, if looked at logically, and/or long enough.
    Nice site!
    I don't have a clue how I came here to it.
    haskinskristin43 - crwdns2934203:0crwdne2934203:0
    Anyone know the Mr. Coffee part number for the white tubing? My Mr. Coffee maker model #BVMC-EVX23. Ty.
    Pam - crwdns2934203:0crwdne2934203:0
  4. Mr. Coffee DW13 Heating Plate Replacement, Heating Plate: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Mr. Coffee DW13 Heating Plate Replacement, Heating Plate: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the Phillips Head #2 screwdriver, remove the two 13 mm screws that secure the silver support bracket.
  5. Mr. Coffee DW13 Heating Plate Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently lift the silver support bracket to free the heating plate from the heating coil.
  6. Mr. Coffee DW13 Heating Plate Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Mr. Coffee DW13 Heating Plate Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pinch and loosen the crimps with the needle-nose pliers.
  7. Mr. Coffee DW13 Heating Plate Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once the crimps are loosened, slide them down the tubing.
  8. Mr. Coffee DW13 Heating Plate Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Mr. Coffee DW13 Heating Plate Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Separate the tubing from the heating coil by grasping the tubing in one hand and the heating coil in the other. Gently pull them apart.
  9. Mr. Coffee DW13 Heating Plate Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Mr. Coffee DW13 Heating Plate Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Place your hand on the front side of the heating plate and push towards the bottom of the coffee maker to pop the heating plate out of place.
Luke Kraemer
crwdns2935283:001/21/14crwdne2935283:0
254 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 10-31, Maness Winter 2014 crwdns2935289:0Cal Poly, Team 10-31, Maness Winter 2014crwdne2935289:0
CPSU-MANESS-W14S10G31
so where do you get a replacement heating element (Im looking for one for a FTX49)
John Baker - crwdns2934203:0crwdne2934203:0
You're missing steps and including unnecessary steps in this instruction. As well, you don't give a source for replacement warming plates. You might want to consider a rewrite.
chase canadé - crwdns2934203:0crwdne2934203:0
I made a substitute hot plate from some sheet metal that I bought at the hardware store, and now I’m back in action with my delicious coffee.
Why they manufacture these plates out of poorly protected mild steel is beyond me. No, actually it isn’t beyond me - using inexpensive, unsuitable components certainly increases their profits. These plates almost certainly cost them less than 1¢ each, which is far cheaper than the 2¢ they’d pay for a suitable, durable part.
Lance J -
Before removing anything, do an in circuit resistance of those two small copper colored cylinders with a black end.
They are thermal fuses, and should have in circuit resistances close to zero.
Their placement is important, especially the one under the silver support bracket.
gdrgry34fsdf324 - crwdns2934203:0crwdne2934203:0
Our plate rusted out and quit heating very effectively. Will try a new part?
Kathy Oliveira - crwdns2934203:0crwdne2934203:0
one question... where do you get the plate, mine is rusty??? LOL
James J Farrell IV - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 33
crwdns2942667:0crwdne2942667:0 8,032
