Use a Phillips #1 screwdriver to remove the two 9mm screws and the three 11mm screws on the bottom of the coffee maker and remove the bottom plastic cover.
Using a Phillips #1 screwdriver, remove 12mm screws from heating element bracket and remove bracket.
Twist warming plate clockwise so that the tab is out of place. Remove warming plate.
Interesting that you can take the thing apart, do nothing else but put it back together again, and it’s supposed to be fixed? What about the step of replacing the broken part? I don’t see mention of that.
