Mr. Coffee BVMC-PC05BL2-NP Disassembly
  1. Mr. Coffee BVMC-PC05BL2-NP Disassembly, Mr. Coffee BVMC-PC05BL2-NP: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Begin with your Mr. Coffee machine on a flat surface.
    • Orient your coffee maker upside down.
  2. Mr. Coffee BVMC-PC05BL2-NP Disassembly: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the three 15 mm screws from the bottom of the machine using a Y1 Tri-point screwdriver.
  3. Mr. Coffee BVMC-PC05BL2-NP Disassembly: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two 15 mm screws from the metal bar using a Phillips #1 screwdriver.
    • Remove the metal bar.
    • Remove the two screws holding the cord.
    • Remove the plastic clip that held the cord.
  4. Mr. Coffee BVMC-PC05BL2-NP Disassembly: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the black shell on the left by unclipping its clips to reveal the LCD circuit board.
  5. Mr. Coffee BVMC-PC05BL2-NP Disassembly: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently pry out the circuit board.
    • The circuit board is particularly fragile, so be very careful while removing it.
  6. Mr. Coffee BVMC-PC05BL2-NP Disassembly: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Put on eye protection.
    • Break the outer shell to access the electronic components.
    • Plastic edges can be sharp. Make sure to be cautious to avoid injuring yourself.
  7. Mr. Coffee BVMC-PC05BL2-NP Disassembly: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove electronic components in one part.
    • In this coffee machine, you begin by filling the water reservoir. Next, you insert a paper filter filled with coffee grounds into the brew basket.
    • The user selects whether they would like to “Brew Now” or “Brew Later.” If they choose to “Brew Now”, the heating metal at the base of the machine begins to heat up. This both warms the plate that the carafe sits upon, and heats the water that drain down from the reservoir and passes through the heater.
    • Once the water is hot enough, the boiling water begins to rise through the second tube into the head that begins showering extremely hot water over the coffee grounds, dripping coffee into the carafe.
Ellie B
crwdns2935283:009/10/24crwdne2935283:0
195 crwdns2915208:0crwdne2915208:0
Tufts University School of Engineering, Team 1-10, Carlson Fall 2024 crwdns2935289:0Tufts University School of Engineering, Team 1-10, Carlson Fall 2024crwdne2935289:0
TUFTS-CARLSON-F24S1G10
crwdns2936753:030crwdne2936753:0 42
crwdns2942667:0crwdne2942667:0 495
