Mpow 059 Ear Cushion Replacement
  1. Mpow 059 Ear Cushion Replacement, Ear Cushion: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Mpow 059 Ear Cushion Replacement, Ear Cushion: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Place the iFixit opening tool between the soft ear cushion and the hard plastic of the speaker.
    • Pry the soft ear cushion away from the hard plastic using a moderate amount of pressure.
    • There is adhesive holding the ear cushion to the speaker so it may take a little patience to remove.
    • Applying too much pressure can damage ear cushion.
    You state the battery is behind the right ear cup, it was behind the left cup on mine. The picture shows "L".
    Art Horton - crwdns2934203:0crwdne2934203:0
    Hi Art, thank you for pointing this out! We will make that correction. Sorry for any confusion.
    Sarah Westberg -
  2. Mpow 059 Ear Cushion Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the ear cushion away from the speaker to completely detach it from the headphones.
    Und was weiter. Wie soll ich die neue Ohrpolster an Die Kopfhörer montieren???
    Markieton - crwdns2934203:0crwdne2934203:0
crwdns2935229:08crwdne2935229:0
Danielle Furtado
crwdns2935283:003/25/22crwdne2935283:0
511 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team E-1, Gurgel Spring 2022 crwdns2935289:0UMass Dartmouth, Team E-1, Gurgel Spring 2022crwdne2935289:0
UMASSD-GURGEL-S22SEG1
crwdns2947412:08crwdne2947412:0
thank you. very helpfule.
P Gill - crwdns2934203:0crwdne2934203:0
These instructions do not mention anything about the fact that you need a new adhesive to make the new earpads stay. Now I won't have headphones until I'm able to purchase an adhesive.
Cody Owens - crwdns2934203:0crwdne2934203:0
Is there a recommendation on the replacement ear pads?
Some say glue is needed but does this depend on the replacement pads?
ms13sp - crwdns2934203:0crwdne2934203:0
Works great. I have replaced my earpads 3 times with no glue. I use these MOKOS earpads from amazon. Replacement earpads for Mpow 059
Thanks for the step by step guide. I love these Mpow headphones, mostly for the controls on the right ear.
anotherdee - crwdns2934203:0crwdne2934203:0
Wie soll ich die neue Ohrpolster montieren. Brauch man ein Kleber da zu und wenn ja, welche??
Wie soll ich die neue Ohrpolster auf meine Kopfhörer montieren, brauche ich ein Kleber und wenn ja, welche?
Per this Video - https://www.youtube.com/watch?v=ytQSCxTP...
It shows the ear pad ring gets slipped under retainers on the black plastic ring that snaps off with the ear pad during the removal process, then snapped back on. The video shows no adhesive being used. Though you can use some if it makes you feel better. Probably use a rubber glue in case you ever want to remove them again. (FYI - The video shows the removal process as being much easier than it is, She probably removed it prior to filming and put it back to make the video move along more quickly. The guide provided in this page is more accurate as far as the removal taking some time and care) Unless the replacement pads you purchased doesn't have the soft ring at the base to slip around the retainers (not sure it that type exist) It shouldn't require adhesive.
Martin Norvaisa - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 21
crwdns2936753:030crwdne2936753:0 93
crwdns2942667:0crwdne2942667:0 7,618
