Mpow 059 Battery Replacement
  1. Mpow 059 Battery  Replacement, Ear Cushion: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Mpow 059 Battery  Replacement, Ear Cushion: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Place the iFixit opening tool between the soft ear cushion and the hard plastic of the speaker.
    • Pry the soft ear cushion away from the hard plastic using a moderate amount of pressure.
    • There is adhesive holding the ear cushion to the speaker so it may take a little patience to remove.
    • Applying too much pressure can damage ear cushion.
  2. Mpow 059 Battery  Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the ear cushion away from the speaker to completely detach it from the headphones.
  3. Mpow 059 Battery  Replacement, Battery: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Mpow 059 Battery  Replacement, Battery: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the Phillips #1 screwdriver to remove the six screws holding the red plastic cover in place.
    • Carefully peel the plastic cover off the left cup to reveal the ear cup's internal components.
    • There is some adhesive holding the red cover down so be careful as you remove it so it doesn't break or crack.
  4. Mpow 059 Battery  Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the JIS J00 screwdriver to remove the 3 screws that secure the black cover.
  5. Mpow 059 Battery  Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the black cover to reveal the battery. The battery is attached to the back of the black cover.
    • The plastic cover of the headphones is connected to the battery housing by a wire connector. Be careful not to harm this cable by pulling the cap too hard during disassembly.
    • Undo the cable and remove the battery.
Danielle Furtado
crwdns2935283:003/25/22crwdne2935283:0
511 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team E-1, Gurgel Spring 2022 crwdns2935289:0UMass Dartmouth, Team E-1, Gurgel Spring 2022crwdne2935289:0
UMASSD-GURGEL-S22SEG1
crwdns2947412:08crwdne2947412:0
Hello
What kind of glue should I use to put new pad?
Martin Dromigny - crwdns2934203:0crwdne2934203:0
What is the part number for the replacement battery? Where can I find one?
hdm_1@comcast.net - crwdns2934203:0crwdne2934203:0
Battery is a 503030 3.7v 420mAh
Mark Jobe - crwdns2934203:0crwdne2934203:0
First, you need to pry the piece behind the R headphone, which is itself adhered. THEN you need to pry the battery off of the backing.
And finally, you can realize you did all of this for nothing if you don't know how to solder. The battery cables are soldered onto the chip, making it impossible to replace without soldering in the replacement wires.
biggles1701 bob - crwdns2934203:0crwdne2934203:0
This is good to know. I was thinking there was something missing as to how the battery is connected. While I'd like to save my headphones from the landfill, it looks like a case of planned obsolescence. Guess I'll be hunting for new headphones with better repair-ability
Nell -
crwdns2936753:030crwdne2936753:0 89
crwdns2942667:0crwdne2942667:0 7,020
