crwdns2959928:0crwdne2959928:0 ↓If you have trouble with your mount plate or want to replace it, this guide will give you detailed steps to follow in order to successfully replace your mounting plate. This replacement should take approximately 5-10 minutes to complete.
Hold Ring Spotlight Cam and hold it backward to you.
Remove the screw using the screwdriver and head tool PH00.
Press the mounting plate button and slide upwards.
Hello, hope you are doing well. Does anyone know if we can buy a replacement mounting plate for the Ring Spotlight Cam Battery? Mine is cracked and Ring doesn’t seem to sell replacements. Thanks!
Suresh Ram - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
