This guide outlines how to replace an LCD screen on the Moultrie I45 GameSpy camera
Using a Philips head screwdriver, remove the eight 6mm screws located at the bottom of the device.
Remove the butterfly nut from the lid arm.
Using a Phillips head screwdriver, remove the six 4mm screws from the face of the camera.
Gently separate the two halves of the case.
Using a Philips head screwdriver, remove the 12, 3mm screws from the board.
Gently remove the circuit board from the face of the camera
Mention the two pieces (black piece) of the LCD screen that you need to remove
make sure to add commas.
Step 1- remove the 8, 6mm...
Step 2- Using a philips head screwdriver, remove the 6, 4mm screws...
Same thing with step 6. Good page!
Jesica Bartell - crwdns2934203:0crwdne2934203:0
