Motorola i450 Boost Mobile Keypad Replacement
    1. Motorola i450 Boost Mobile Keypad Replacement, Back Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Motorola i450 Boost Mobile Keypad Replacement, Back Cover: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Motorola i450 Boost Mobile Keypad Replacement, Back Cover: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Place the phone on a flat surface with the front facing down.
      • Insert your finger under the gray plastic cover at the bottom end of the phone.
      • Lift the cover off the phone.
    1. Motorola i450 Boost Mobile Keypad Replacement, Battery: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Motorola i450 Boost Mobile Keypad Replacement, Battery: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Motorola i450 Boost Mobile Keypad Replacement, Battery: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Place your thumb in the notch in the lower left corner of the battery compartment.
      • Lift the battery up and away from the phone.
      • Remove the battery.
    1. Motorola i450 Boost Mobile Keypad Replacement, SIM Card: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola i450 Boost Mobile Keypad Replacement, SIM Card: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Locate the metal slider that holds the SIM card in place.
      • Push the slider away from the metal flap which contains the SIM card. The flap will pop up.
    2. Motorola i450 Boost Mobile Keypad Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Motorola i450 Boost Mobile Keypad Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Motorola i450 Boost Mobile Keypad Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Lift the metal flap to gain access to the bottom of the SIM card.
      • Remove the SIM card by sliding it out parallel to the bottom of the flap.
    1. Motorola i450 Boost Mobile Keypad Replacement, Circuit Board: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Extend the antenna.
    2. Motorola i450 Boost Mobile Keypad Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the four 4.8 mm Torx T6 screws from the corners of the back of the phone.
      • If the antenna is not fully extended, the top left screw will not be accessible.
    3. Motorola i450 Boost Mobile Keypad Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Motorola i450 Boost Mobile Keypad Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Motorola i450 Boost Mobile Keypad Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Gently lift off the back half of the phone and set to the side.
      • Permanent circuit connections prevent the cover from completely separating from the phone. Do not attempt to disconnect these circuits.
    1. Motorola i450 Boost Mobile Keypad Replacement, Keypad: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Motorola i450 Boost Mobile Keypad Replacement, Keypad: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Motorola i450 Boost Mobile Keypad Replacement, Keypad: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Gently lift the end of the circuit board farthest from the phone hinge.
      • The circuit board is permanently connected to the phone casing at the end nearest to the hinge.
      • Grasp the keypad at the bottom of the phone, raise it, and pull it away.
Garrison Stevens
crwdns2935283:010/22/12crwdne2935283:0
1 crwdns2915208:0crwdne2915208:0
Clemson, Team 15-2, Benson Fall 2012 crwdns2935289:0Clemson, Team 15-2, Benson Fall 2012crwdne2935289:0
CLEM-BENSON-F12S15G2
crwdns2935297:0108crwdne2935297:0
crwdns2942667:0crwdne2942667:0 781
