Motorola Xoom Wifi Battery Replacement
  1. Motorola Xoom Wifi Battery Replacement, Back Cover Disassembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola Xoom Wifi Battery Replacement, Back Cover Disassembly: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • There are two 6.6 mm screws that hold ports into place as well as the back panel. Remove these with a T5 Torx screwdriver.
  2. Motorola Xoom Wifi Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola Xoom Wifi Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Apply light pressure with hand and slide the back plate till it stops in this position.
    • There is a flex clip on both sides that need to be pushed down in order for the plate to slide off completely. Use a plastic opening tool to release the flex clips. They are located under the back cover near the sides.
    • As soon as the clips are released the back should slide off.
  3. Motorola Xoom Wifi Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Motorola Xoom Wifi Battery Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Motorola Xoom Wifi Battery Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove last two 4.2 mm screws from the remaining back piece with a T5 Torx screwdriver.
    • Once both screws are taken out, lift the rest of the backing out of the way.
  4. Motorola Xoom Wifi Battery Replacement, Battery: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola Xoom Wifi Battery Replacement, Battery: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two battery leads with a T-5 Torx screwdriver.
    • Grab the red and black wires with your fingers and gently lift to disconnect black wire connector from the motherboard.
  5. Motorola Xoom Wifi Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola Xoom Wifi Battery Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • All that holds the battery in are twelve screws. Remove them with a T-6 Torx screwdriver.
    • The battery should lift out easily.
Andrew Mercier
crwdns2935283:004/14/14crwdne2935283:0
532 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 3-39, Maness Spring 2014 crwdns2935289:0Cal Poly, Team 3-39, Maness Spring 2014crwdne2935289:0
CPSU-MANESS-S14S3G39
does anyone know what the function of the black and red wires are? my connector came off the motherboard.
Duli - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 4,813
