Motorola Xoom Wifi Back-Facing Camera Replacement
  1. Motorola Xoom Wifi Back-Facing Camera Replacement, Back Cover Disassembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola Xoom Wifi Back-Facing Camera Replacement, Back Cover Disassembly: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • There are two 6.6 mm screws that hold ports into place as well as the back panel. Remove these with a T5 Torx screwdriver.
  2. Motorola Xoom Wifi Back-Facing Camera Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola Xoom Wifi Back-Facing Camera Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Apply light pressure with hand and slide the back plate till it stops in this position.
    • There is a flex clip on both sides that need to be pushed down in order for the plate to slide off completely. Use a plastic opening tool to release the flex clips. They are located under the back cover near the sides.
    • As soon as the clips are released the back should slide off.
  3. Motorola Xoom Wifi Back-Facing Camera Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Motorola Xoom Wifi Back-Facing Camera Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Motorola Xoom Wifi Back-Facing Camera Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove last two 4.2 mm screws from the remaining back piece with a T5 Torx screwdriver.
    • Once both screws are taken out, lift the rest of the backing out of the way.
  4. Motorola Xoom Wifi Back-Facing Camera Replacement, Back-Facing Camera: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola Xoom Wifi Back-Facing Camera Replacement, Back-Facing Camera: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger or a fine tip to lift the black tab to a vertical position.
    • A spudger is needed to remove the plastic border around the camera.
  5. Motorola Xoom Wifi Back-Facing Camera Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola Xoom Wifi Back-Facing Camera Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • When lifting the camera out, be sure to pull the orange ribbon cable as well.
Andrew Mercier
crwdns2935283:004/14/14crwdne2935283:0
532 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 3-39, Maness Spring 2014 crwdns2935289:0Cal Poly, Team 3-39, Maness Spring 2014crwdne2935289:0
CPSU-MANESS-S14S3G39
crwdns2936753:030crwdne2936753:0 7
crwdns2942667:0crwdne2942667:0 443
