Motorola Xoom 2 Charging Port Replacement
  1. Motorola Xoom 2 Charging Port Replacement, Backplate: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Motorola Xoom 2 Charging Port Replacement, Backplate: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Motorola Xoom 2 Charging Port Replacement, Backplate: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pry off the silver top back cover (the panel around the camera) with iFixit opening picks or a similar implement.
  2. Motorola Xoom 2 Charging Port Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola Xoom 2 Charging Port Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a T5 screwdriver, unscrew the four 1.5mm screws holding the main back cover. These screws are arranged in a line across the top of the back of the device.
  3. Motorola Xoom 2 Charging Port Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Motorola Xoom 2 Charging Port Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Motorola Xoom 2 Charging Port Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Turn the device over and using a pry tool and the opening picks, gently apply pressure between the outside edge of the seal marked with the arrow. Slowly move around the edges of the device, applying even pressure, and separate the back plate from the display.
    • There is adhesive between the back-plate and battery.
  4. Motorola Xoom 2 Charging Port Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the back plate from your device.
  5. Motorola Xoom 2 Charging Port Replacement, Charging Port: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola Xoom 2 Charging Port Replacement, Charging Port: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using tweezers, gently pry up the piece of yellow Kapton tape that is holding several cables in place.
    • Set this piece of tape aside, as it is required for reassembly.
  6. Motorola Xoom 2 Charging Port Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Motorola Xoom 2 Charging Port Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Motorola Xoom 2 Charging Port Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using a spudger, carefully disconnect the 3 pin cable.
    • The 3 pin cable connectors are made of soft, easily breakable plastic. Take care not to use unnecessary force during repair.
    • Then carefully disconnect the flat yellow ribbon cable at both connection points.
  7. Motorola Xoom 2 Charging Port Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola Xoom 2 Charging Port Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a Torx T5 driver bit, unscrew the two 1.5mm screws holding down the charging port assembly.
  8. Motorola Xoom 2 Charging Port Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola Xoom 2 Charging Port Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a spudger, gently apply pressure between the chassis and charging port assembly to remove it.
    • The charging port should be free from the chassis and require little to no force to remove.
    • The rubber jacket covering the charging port assembly may need to be removed and reused, depending on whether or not the replacement comes with another one.
Ryker Hull
crwdns2935283:009/18/19crwdne2935283:0
383 crwdns2915208:0crwdne2915208:0
Embry-Riddle Aeronautical University, Team S13-G6, Lamothe Fall 2019 crwdns2935289:0Embry-Riddle Aeronautical University, Team S13-G6, Lamothe Fall 2019crwdne2935289:0
ERAU-LAMOTHE-F19S13G6
crwdns2936753:030crwdne2936753:0 8
crwdns2942667:0crwdne2942667:0 711
