Motorola W385 speaker replacement
  1. Motorola W385 speaker replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using your finger, press down on the clip holding the back cover on.
  2. Motorola W385 speaker replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the spudger or your finger, gently pull the battery out from the top.
  3. Motorola W385 speaker replacement, Front Casing: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four rubber pieces from the face of the phone using the sharp end of the spudger.
    • The rubber pieces are held in with a mild adhesive.
  4. Motorola W385 speaker replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four Torx-6 screws from underneath the rubber pieces.
  5. Motorola W385 speaker replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola W385 speaker replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Close the phone before proceeding.
    • Using the flat end of the spudger, insert it under the plastic at the top left of the phone.
    • Gently, although a small amount of force is required, use a twisting motion to pull the plastic casing away from the body of the phone.
    • Continue to move around the phone counter clockwise until the casing is separated from the body.
    • It is not unusual for it to pop off before making it back to the starting point.
  6. Motorola W385 speaker replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • If the casing has not popped off of the body, remove it carefully from the the phone.
  7. Motorola W385 speaker replacement, Top Logic Board: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • After completing Steps 3-6 in the casing repair guide, your phone should look like this.
  8. Motorola W385 speaker replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Motorola W385 speaker replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Motorola W385 speaker replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the spudger to unhinge the four clips around the metal casing of the top logic board.
    • Gently take off the metal casing of the logic board.
  9. Motorola W385 speaker replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Motorola W385 speaker replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Motorola W385 speaker replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use spudger to gently disconnect the ribbon cable from phone.
    • Gently remove Logic Board making sure not to damage any other components.
  10. Motorola W385 speaker replacement, Main Speaker: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Ignoring the top logic board, take the phone in your hand and turn your attention towards the speaker.
  11. Motorola W385 speaker replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola W385 speaker replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Place the spudger between the speaker and the clip shown.
    • Separate the clip from the speaker while lifting on the speaker.
    • The speaker should separate. Use the tweezers to grab the speaker.
Koedy Brant
crwdns2935283:001/26/10crwdne2935283:0
41 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 8-50, Regan Winter 2010 crwdns2935289:0Cal Poly, Team 8-50, Regan Winter 2010crwdne2935289:0
CPSU-REGAN-W10S8G50
crwdns2942667:0crwdne2942667:0 3,244
