This will show you how to disassemble the top logic board
Using your finger, press down on the clip holding the back cover on.
Using the spudger or your finger, gently pull the battery out from the top.
Remove the four rubber pieces from the face of the phone using the sharp end of the spudger.
Remove the four Torx-6 screws from underneath the rubber pieces.
Close the phone before proceeding.
Using the flat end of the spudger, insert it under the plastic at the top left of the phone.
Gently, although a small amount of force is required, use a twisting motion to pull the plastic casing away from the body of the phone.
Continue to move around the phone counter clockwise until the casing is separated from the body.
If the casing has not popped off of the body, remove it carefully from the the phone.
After completing Steps 3-6 in the casing repair guide, your phone should look like this.
Use the spudger to unhinge the four clips around the metal casing of the top logic board.
Gently take off the metal casing of the logic board.
Use spudger to gently disconnect the ribbon cable from phone.
