Motorola W385 Bottom Casing Replacement
  1. Motorola W385 Bottom Casing Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using your finger, press down on the clip holding the back cover on.
  2. Motorola W385 Bottom Casing Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the spudger or your finger, gently pull the battery out from the top.
  3. Motorola W385 Bottom Casing Replacement, Bottom Casing: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Hold the phone as shown in the photo.
  4. Motorola W385 Bottom Casing Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola W385 Bottom Casing Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the flat side of the spudger and a little pressure, insert it under the bottom plastic piece at about center.
    • This might require a little persistence due how the beveled plastic rests on the phone body.
    • After the spudger is under the plastic piece, move counter clockwise using a gentle twisting motion until the piece is free from the phone body.
  5. Motorola W385 Bottom Casing Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two Torx-6 screws under the removed plastic.
  6. Motorola W385 Bottom Casing Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Keeping the phone open, turn it over allowing the battery compartment to be visible.
    • Remove the four Torx-6 screws from the back plastic.
  7. Motorola W385 Bottom Casing Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Motorola W385 Bottom Casing Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Motorola W385 Bottom Casing Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Hold the phone with the keys facing down and the mini USB charging port visible.
    • Open the rubber flap covering the charging port.
    • Insert the flat end of the spudger just above the charging port.
    • Using the same gentle twisting motion, work around the bottom of the phone and up the opposite side. The back casing should separate from the body of the phone.
    • When working on the thinner pieces of the plastic casing, use caution insuring the plastic does not crack.
  8. Motorola W385 Bottom Casing Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The casing can be easily removed exposing the bottom logic board.
Austin Hobbs
crwdns2935283:001/21/10crwdne2935283:0
69 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 8-50, Regan Winter 2010 crwdns2935289:0Cal Poly, Team 8-50, Regan Winter 2010crwdne2935289:0
CPSU-REGAN-W10S8G50
crwdns2942667:0crwdne2942667:0 3,477
