Motorola V710 Logic Board Replacement
  1. Motorola V710 Logic Board Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Motorola V710 Logic Board Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Motorola V710 Logic Board Replacement, Battery: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Press down on the back button while pulling away from the body of the phone to release the back cover.
  2. Motorola V710 Logic Board Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Motorola V710 Logic Board Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Motorola V710 Logic Board Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the battery from the phone by gently pulling upward on the battery with your fingers.
  3. Motorola V710 Logic Board Replacement, Logic Board: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola V710 Logic Board Replacement, Logic Board: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew and remove the antenna by gripping the base and twisting clockwise.
    • Once the antenna has passed the threading, pull out.
  4. Motorola V710 Logic Board Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola V710 Logic Board Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the screws from the upper side of the phone with the T6 Torx screwdriver.
    • The first screw is underneath where the antenna was and the other is visible to the right.
  5. Motorola V710 Logic Board Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Motorola V710 Logic Board Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Motorola V710 Logic Board Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the spudger under the left corner of the bottom plate.
    • Using a twist and pry motion seperate the bottom plate and work your way to the right.
    • This can be somewhat difficult and require a good deal of work.
  6. Motorola V710 Logic Board Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola V710 Logic Board Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the T6 Torx screwdriver to remove the bottom two screws.
  7. Motorola V710 Logic Board Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola V710 Logic Board Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert the spudger between the key plate and the back of the phone and work your way around the edge of the phone to pop keys off.
    • There is one clasp on either side that needs to be removed before the keys come off.
    • This step is extremely hard and may require time, strength, endurance, and multiple spudgers.
  8. Motorola V710 Logic Board Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Motorola V710 Logic Board Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Motorola V710 Logic Board Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the pressure plate forward to expose the logic board.
    • Use the spludger to pry off the plug that connects pressure pad to the logic board.
    • Remove the pressure pad.
  9. Motorola V710 Logic Board Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the spudger to pry off the plug that connects logic board to the screen.
  10. Motorola V710 Logic Board Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola V710 Logic Board Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the logic board.
Karl Sanders
crwdns2935283:001/26/10crwdne2935283:0
8 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 8-49, Regan Winter 2010 crwdns2935289:0Cal Poly, Team 8-49, Regan Winter 2010crwdne2935289:0
CPSU-REGAN-W10S8G49
crwdns2936753:030crwdne2936753:0 67
crwdns2942667:0crwdne2942667:0 2,320
