How to replace the keypad and keypad logic board.
Depress the silver button.
Pull from top of phone to lift the cover.
Hold battery from both sides at the bottom.
Push upwards and gently lift to remove.
Remove 4 screws from corners using T-6 screwdriver.
Use plastic opening tool to pry up back cover from two side clips.
Use a plastic opening tool to gently remove the orange ribbon cable.
Lift up the main logic board.
NOTE: Rubber side buttons are not secure and might detach from the main logic board during removal.
