Motorola V557 Screen Replacement
    1. Motorola V557 Screen Replacement, Faceplate: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Motorola V557 Screen Replacement, Faceplate: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Motorola V557 Screen Replacement, Faceplate: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Remove the four rubber stoppers from around the screen with a pin to reveal four screws.
    2. Motorola V557 Screen Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola V557 Screen Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the four 3.8 mm T-6 Torx screws.
    3. Motorola V557 Screen Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola V557 Screen Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Separate the cover from the edges using a plastic opening tool.
    4. Motorola V557 Screen Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola V557 Screen Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • With the edges separated, close the phone and lift off the faceplate with your fingers.
    1. Motorola V557 Screen Replacement, Camera: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Gently peel off the plastic film from the metal plate above the camera lens as shown.
    2. Motorola V557 Screen Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola V557 Screen Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Insert the spudger into the slots marked and gently pry upwards to remove the metal cover.
      • Repeat the previous bullet for the two corresponding tabs on the opposite side of the phone.
    3. Motorola V557 Screen Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola V557 Screen Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Lift and peel back the tape attaching metal casing to body of the phone.
      • Gently lift the metal cover and remove to expose the circuit board.
    4. Motorola V557 Screen Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola V557 Screen Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Using a plastic opening tool, pry or lift open the pink door shown.
      • After the door is open, gently pull on the ribbon cable's corner to separate it from the board.
      • Work out the ribbon cable's end slowly and gently to avoid damaging the pink door port.
    5. Motorola V557 Screen Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Motorola V557 Screen Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Motorola V557 Screen Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Use a plastic opening tool to dislodge and remove the rubber camera cover.
    6. Motorola V557 Screen Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola V557 Screen Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Lift the top ribbon cable, with camera attached, up and away from the rest of the phone.
    1. Motorola V557 Screen Replacement, Screen: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Motorola V557 Screen Replacement, Screen: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Motorola V557 Screen Replacement, Screen: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Pull the ribbon cable up and out of the way to get access to the circuit board-screen unit.
      • Using a plastic opening tool, gently pry and remove the circuit board-screen unit in both screens.
Blair Frandeen
crwdns2935283:010/02/10crwdne2935283:0
19 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 7-50, Amido Fall 2010 crwdns2935289:0Cal Poly, Team 7-50, Amido Fall 2010crwdne2935289:0
CPSU-AMIDO-F10S7G50
crwdns2935297:0144crwdne2935297:0
crwdns2942667:0crwdne2942667:0 3,190
