Motorola V557 Headphone Jack Replacement
  1. Motorola V557 Headphone Jack Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Motorola V557 Headphone Jack Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Motorola V557 Headphone Jack Replacement, Battery: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • First, on the back of the phone find the silver button on the top left corner of the phone.
    • Simultaneously push down the button and slide the back plate down to reveal the battery.
  2. Motorola V557 Headphone Jack Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola V557 Headphone Jack Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Grab the lower edge of the battery at the two bottom corners.
    • Pull upward on the edges to remove the battery.
  3. Motorola V557 Headphone Jack Replacement, SIM Card: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Motorola V557 Headphone Jack Replacement, SIM Card: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Motorola V557 Headphone Jack Replacement, SIM Card: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Push the metal slider towards the top of the phone until it clicks out of the original position.
    • Gently slide out and remove the SIM card.
  4. Motorola V557 Headphone Jack Replacement, Antenna: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola V557 Headphone Jack Replacement, Antenna: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Grip the antenna and twist it counterclockwise to loosen it.
    • When it has been loosened all the way, pull gently to remove the antenna piece.
  5. Motorola V557 Headphone Jack Replacement, Rear Casing: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Motorola V557 Headphone Jack Replacement, Rear Casing: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Motorola V557 Headphone Jack Replacement, Rear Casing: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using the push pin, gently pry the top two screws of the cover off.
    • The cover in the upper left of the back plate does not need to be removed.
  6. Motorola V557 Headphone Jack Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Motorola V557 Headphone Jack Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Motorola V557 Headphone Jack Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • At the corners of the phone, remove all four 6.0 mm Torx screws, using your screwdriver.
  7. Motorola V557 Headphone Jack Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Motorola V557 Headphone Jack Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Motorola V557 Headphone Jack Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Next, insert a spudger into the marked holes. One at a time pry away from the phone to release the internal tabs.
    • Then, separate and detach the rear casing.
  8. Motorola V557 Headphone Jack Replacement, Headphone Jack: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Motorola V557 Headphone Jack Replacement, Headphone Jack: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Motorola V557 Headphone Jack Replacement, Headphone Jack: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lastly, using a push pin, lift out and to the left to release the headphone jack assembly.
    • Insert the new headphone jack assembly and repeat these steps in reverse order.
Alex Georges
crwdns2935283:010/02/10crwdne2935283:0
40 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 7-50, Amido Fall 2010 crwdns2935289:0Cal Poly, Team 7-50, Amido Fall 2010crwdne2935289:0
CPSU-AMIDO-F10S7G50
crwdns2942667:0crwdne2942667:0 1,684
