Motorola V551 Keypad Key Replacement
    1. Motorola V551 Keypad Key Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola V551 Keypad Key Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Press down on the chrome button on the bottom of the chassis. Simultaneously slide the back cover down, away from the phone.
    2. Motorola V551 Keypad Key Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Lever the battery out by pressing upwards on the bottom corners of the battery.
    1. Motorola V551 Keypad Key Replacement, Circuit Board: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Motorola V551 Keypad Key Replacement, Circuit Board: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Motorola V551 Keypad Key Replacement, Circuit Board: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Remove the rubber screw covers using a plastic spudger.
      • Use a T6 Torx screwdriver to remove the screws underneath the rubber screw covers.
    2. Motorola V551 Keypad Key Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Unscrew the antenna.
    3. Motorola V551 Keypad Key Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Motorola V551 Keypad Key Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Motorola V551 Keypad Key Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Gently release the two latches using an opening tool.
      • The plastic latches are very fragile. Don’t use excessive force or they might break.
      • Pry off the back panel by wedging an opening tool into the crevice between the back panel and the circuit board.
      • Lift the back panel off of the phone.
    4. Motorola V551 Keypad Key Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola V551 Keypad Key Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Loosen the copper circuit board connection with an opening tool.
      • Gently lift the copper connection.
    5. Motorola V551 Keypad Key Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Motorola V551 Keypad Key Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Motorola V551 Keypad Key Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Lift up and pull out the pressure pad from under the buttons on the side of the chassis.
      • Gently lift the motherboard off of the front panel.
    1. Motorola V551 Keypad Key Replacement, Keypad: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Motorola V551 Keypad Key Replacement, Keypad: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Motorola V551 Keypad Key Replacement, Keypad: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Push both side keys in so they are not sticking out of the phone.
      • Remove the keypad.
    1. Motorola V551 Keypad Key Replacement, Keypad Key: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola V551 Keypad Key Replacement, Keypad Key: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Gently squeeze the bottle of super glue so that only a small amount (about 1/3 pinky width) is a applied to the back side of the key.
      • Be careful while applying the super glue as it can be quite strong.
    2. Motorola V551 Keypad Key Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola V551 Keypad Key Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Carefully place key onto the key pad so that it will be properly oriented and in line with the other keys.
gregatron
crwdns2935283:010/29/09crwdne2935283:0
105 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 6-6, Maness Fall 2009 crwdns2935289:0Cal Poly, Team 6-6, Maness Fall 2009crwdne2935289:0
CPSU-MANESS-F09S6G6
crwdns2936751:024crwdne2936751:0 11
crwdns2936753:07crwdne2936753:0 21
crwdns2936753:030crwdne2936753:0 41
crwdns2942667:0crwdne2942667:0 2,424
