This guide will instruct you how to remove and successfully replace the main screen on the phone.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Remove the 4 stoppers surrounding the main screen with tweezers.
Use a Torx T-6 Screwdriver to unscrew the 4 screws around the screen.
Use a plastic opening tool to separate outer shell from metal interior cover.
Use plastic opening tool to to separate inner metal cover from the circuit board. Apply pressure to remove the piece.
Insert black spudger beneath circuit board to pry it from phone screen.
Apply pressure to remove the screen from its adhesive backing on the plastic.
Place new screen on the phone.
