Press and hold the button on the battery cover
Pull the battery cover down and out to remove it
Remove the batteries by pulling them away from the phone
Using the Torx T4 screwdriver remove the six screws highlighted in the picture to the left
Use your fingers or a spudger to remove the back cover
Lift and remove buttons by hand
Place your plastic opening tool in between the motherboard and the front cover of the phone
Apply a small force to lift the motherboard away from the front cover
Grip the top of the rubber keypad with your thumb and index finger
While holding the keypad start to peel it back from the front cover until the keypad is completely detached
Use the iFixit opening tool to lift the speaker off the front cover.
Once the motherboard, speaker, and keypad have been removed you should have the front cover by itself
