The two way radio speaker is responsible for broadcasting the signal received, making it a very important part. Follow the steps below to properly replace the speaker of the radio.
Remove the back battery cover by pressing the tab to the left, and lifting.
Remove the batteries currently in the radio.
The orientation of the batteries is specified in the battery compartment.
Turn the Volume knob to the off position.
Firmly grasp and pull back on the volume knob. The knob should come off smoothly.
Remove the four 3 millimeter T6 Torx screws from the front of the radio.
Remove the four 3 millimeter T8 Torx screws from the back of the radio.
Gently open the backplate of the radio. Use a flathead screwdriver to slowly pry apart the two sides.
Gently pull the circuit board away from the front faceplate.
To remove the speaker from the faceplate, insert a paperclip through the front faceplate and push.
The speaker is glued to the front faceplate, so it may take some force to remove the speaker.
Now the circuit board can be removed from the back faceplate.
To do this, grip the back faceplate in one hand and the antenna in the other. Pull and twist the antenna away from the back faceplate. The circuit board should be removed with the antenna, as they are attached.
You should end up with just the circuit board and speaker, as seen in the picture.
Remove the wires connecting the speaker to the circuit board with a soldering iron.
The new speaker wires can then be connected to the circuitboard with a soldering iron.
thank you very much!!!!!!!!
What glue is used to reattach speaker to front housing?
Speaker model#?...?
