Motorola SLVR L9 Keypad Replacement
crwdns2869540:0crwdne2869540:0: 818
2
24
87
818
crwdns2959984:0crwdne2959984:0: 0
crwdns2959956:0crwdne2959956:0
crwdns2955944:0crwdne2955944:0: crwdns2931273:0crwdne2931273:0
The Keypad Replacement Guide provides a list of the tools and parts that you need to replace the keypad on the Motorola SLVR L9. As you begin the replacement process, look for the pictures provided with each step to better guide you.
    1. Motorola SLVR L9 Keypad Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola SLVR L9 Keypad Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Turn the phone over so that the back of the phone is facing up.
    2. Motorola SLVR L9 Keypad Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Motorola SLVR L9 Keypad Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Motorola SLVR L9 Keypad Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Press down on the silver battery cover latch located at the top of the phone.
      • Pull the battery cover down and away from the latch; then lift it up to remove the battery cover.
    3. Motorola SLVR L9 Keypad Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Motorola SLVR L9 Keypad Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Motorola SLVR L9 Keypad Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • To remove the battery, pull the battery up from the bottom center.
    1. Motorola SLVR L9 Keypad Replacement, Camera Lens Cover: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola SLVR L9 Keypad Replacement, Camera Lens Cover: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Turn the phone over so that the back of the phone is facing towards you.
    2. Motorola SLVR L9 Keypad Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Motorola SLVR L9 Keypad Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Motorola SLVR L9 Keypad Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Press down on the battery cover latch located at the top of the phone.
    3. Motorola SLVR L9 Keypad Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the four housing screws (1/8") from each corner of the transceiver PC board shield. Use a screwdriver with a T6 Torx screwdriver head to turn the screws counter-clockwise (left).
    4. Motorola SLVR L9 Keypad Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola SLVR L9 Keypad Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Once you have removed all of the screws, lift the transceiver PC board shield up to remove it.
    1. Motorola SLVR L9 Keypad Replacement, Antenna Cover: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Motorola SLVR L9 Keypad Replacement, Antenna Cover: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Motorola SLVR L9 Keypad Replacement, Antenna Cover: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Use the plastic opening tool to loosen the cover latch.
      • Once the cover latch has been loosened, gently pull the cover latch off of the device.
    1. Motorola SLVR L9 Keypad Replacement, Keypad: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use a screwdriver with a T6 Torx screwdriver head to remove both screws (1/8") from the speaker housing. Turn the screw counter-clockwise (left).
    2. Motorola SLVR L9 Keypad Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Motorola SLVR L9 Keypad Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Motorola SLVR L9 Keypad Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Using the grooves around the edge of the phone, gently pull the front plate away from the phone until it is fully removed from the device.
    3. Motorola SLVR L9 Keypad Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola SLVR L9 Keypad Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Lift the keypad up from the front plate to remove.
Eric Lopez
crwdns2935283:010/13/15crwdne2935283:0
201 crwdns2915208:0crwdne2915208:0
Sam Houston State, Team 1-5, Blackburne Fall 2015 crwdns2935289:0Sam Houston State, Team 1-5, Blackburne Fall 2015crwdne2935289:0
SHSU-BLACKBURNE-F15S1G5
crwdns2936753:030crwdne2936753:0 87
crwdns2959996:0crwdne2959996:0 818
