Motorola SLVR L9 Front Panel Replacement
  1. Motorola SLVR L9 Front Panel Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola SLVR L9 Front Panel Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Turn the phone over so that the back of the phone is facing up.
  2. Motorola SLVR L9 Front Panel Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Motorola SLVR L9 Front Panel Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Motorola SLVR L9 Front Panel Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Press down on the silver battery cover latch located at the top of the phone.
    • Pull the battery cover down and away from the latch; then lift it up to remove the battery cover.
  3. Motorola SLVR L9 Front Panel Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Motorola SLVR L9 Front Panel Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Motorola SLVR L9 Front Panel Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • To remove the battery, pull the battery up from the bottom center.
  4. Motorola SLVR L9 Front Panel Replacement, Camera Lens Cover: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola SLVR L9 Front Panel Replacement, Camera Lens Cover: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Turn the phone over so that the back of the phone is facing towards you.
  5. Motorola SLVR L9 Front Panel Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Motorola SLVR L9 Front Panel Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Motorola SLVR L9 Front Panel Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Press down on the battery cover latch located at the top of the phone.
  6. Motorola SLVR L9 Front Panel Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four housing screws (1/8") from each corner of the transceiver PC board shield. Use a screwdriver with a T6 Torx screwdriver head to turn the screws counter-clockwise (left).
  7. Motorola SLVR L9 Front Panel Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola SLVR L9 Front Panel Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Once you have removed all of the screws, lift the transceiver PC board shield up to remove it.
  8. Motorola SLVR L9 Front Panel Replacement, Antenna Cover: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Motorola SLVR L9 Front Panel Replacement, Antenna Cover: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Motorola SLVR L9 Front Panel Replacement, Antenna Cover: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the plastic opening tool to loosen the cover latch.
    • Once the cover latch has been loosened, gently pull the cover latch off of the device.
  9. Motorola SLVR L9 Front Panel Replacement, Front Panel: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a screwdriver with a T6 Torx screwdriver head to turn the screw counter-clockwise (left).
  10. Motorola SLVR L9 Front Panel Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Motorola SLVR L9 Front Panel Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Motorola SLVR L9 Front Panel Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using the grooves around the edge of the phone, gently pull the front panel away from the phone until it is fully removed from the device.
Ivan Sarabia
crwdns2935283:010/13/15crwdne2935283:0
104 crwdns2915208:0crwdne2915208:0
Sam Houston State, Team 1-5, Blackburne Fall 2015 crwdns2935289:0Sam Houston State, Team 1-5, Blackburne Fall 2015crwdne2935289:0
SHSU-BLACKBURNE-F15S1G5
crwdns2936753:030crwdne2936753:0 8
crwdns2942667:0crwdne2942667:0 248
