The Antenna Cover Guide provides a list of the tools and parts that you need to replace the antenna cover on the Motorola SLVR L9. As you begin the replacement process, look for the pictures provided with each step to better guide you.
Turn the phone over so that the back of the phone is facing up.
Press down on the silver battery cover latch located at the top of the phone.
Pull the battery cover down and away from the latch; then lift it up to remove the battery cover.
To remove the battery, pull the battery up from the bottom center.
Use the plastic opening tool to loosen the cover latch.
Once the cover latch has been loosened, gently pull the cover latch off of the device.
