This guide will show you how to remove the motherboard on a Motorola V3c.
Press down on the the rear panel release button while simultaneously prying the rear panel straight away from the V3c.
Lift and remove the rear panel away from the V3c.
Remove the battery by pushing in the top of the battery and lifting it away from the phone.
Unscrew the two screws in the back using the T6.
Use the plastic opening tool to pop the bottom and the sides off the back casing.
Peel off the connector between the motherboard and the body of the phone.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Pull out the two black rubber covers using tweezers.
Pull out the white plastic cover by unclipping the two plastic pieces shown.
Pull out the motherboard.
You may also now replace the bottom lower casing
