Motorola Razr V3c Lower Casing (CDMA) Replacement
  1. Motorola Razr V3c Lower Casing (CDMA) Replacement, Battery (CDMA): crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Motorola Razr V3c Lower Casing (CDMA) Replacement, Battery (CDMA): crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Motorola Razr V3c Lower Casing (CDMA) Replacement, Battery (CDMA): crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Press down on the the rear panel release button while simultaneously prying the rear panel straight away from the V3c.
    • Lift and remove the rear panel away from the V3c.
  2. Motorola Razr V3c Lower Casing (CDMA) Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola Razr V3c Lower Casing (CDMA) Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the battery by pushing in the top of the battery and lifting it away from the phone.
  3. Motorola Razr V3c Lower Casing (CDMA) Replacement, Speaker (CDMA): crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the two screws in the back using the T6.
  4. Motorola Razr V3c Lower Casing (CDMA) Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the plastic opening tool to pop the bottom and the sides off the back casing.
    • Be careful not to pull the back lower cover off too far as it is connected to the phone body by a ribbon.
  5. Motorola Razr V3c Lower Casing (CDMA) Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Peel off the connector between the motherboard and the body of the phone.
  6. Motorola Razr V3c Lower Casing (CDMA) Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola Razr V3c Lower Casing (CDMA) Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull out the two black rubber covers using tweezers.
    • The second rubber cover is much harder to get out.
  7. Motorola Razr V3c Lower Casing (CDMA) Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola Razr V3c Lower Casing (CDMA) Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull out the white plastic cover by unclipping the two plastic pieces shown.
  8. Motorola Razr V3c Lower Casing (CDMA) Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull out the speaker.
  9. Motorola Razr V3c Lower Casing (CDMA) Replacement, Motherboard (CDMA): crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola Razr V3c Lower Casing (CDMA) Replacement, Motherboard (CDMA): crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull out the motherboard.
    • You may also now replace the bottom lower casing
  10. Motorola Razr V3c Lower Casing (CDMA) Replacement, Lower Casing (CDMA): crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the two screws holding the plastic speaker cover to the phone with a T5 screwdriver
  11. Motorola Razr V3c Lower Casing (CDMA) Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull off and replace the lower front casing
    • The metallic grounding grid will come off when the lower front casing is removed
    • Make sure to reinsert the metallic grounding unit when re-screwing the new lower bottom casing
krisko
crwdns2935283:001/14/10crwdne2935283:0
104 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 11-4, Forte Winter 2010 crwdns2935289:0Cal Poly, Team 11-4, Forte Winter 2010crwdne2935289:0
CPSU-FORTE-W10S11G4
crwdns2942667:0crwdne2942667:0 6,382
