In this guide, you will be installing the speaker that is on the bottom of the phone. This speaker is used to make speaker phone calls, play ringtones, and other phone sounds.
            Remove the back cover by pressing down the silver button.
            Pull the cover away from the phone.
            Remove the battery by pushing down on the top and pulling it away from the phone.
            Remove the SIM card by pulling it toward the top of the phone with your thumb.
            Unscrew the two 5mm T6 Torx screws form the phone.
            Pry open the back of the phone using the spudger. There are four clips, one on the left, one on the right, and two on the bottom of the phone.
   crwdns2935267:0crwdne2935267:0Tweezers$4.99-
            Using tweezers, disconnect the copper ribbon on the left side of the phone by pulling it up from the circuit board.
            Remove the antenna by pushing in the tabs on the sides with the spudger, and pulling it out.
            Using the spudger, pry up the primary speaker from the phone.
