This guide will provide the steps to install a new antenna in your Motorola Razr V3. If you are not getting any cell signal or can not connect a call, a broken antenna may be the problem and a new one can be installed using this guide.
Remove the back cover by pressing down the silver button.
Pull the cover away from the phone.
Remove the battery by pushing down on the top and pulling it away from the phone.
Unscrew the two 5mm T6 Torx screws form the phone.
Pry open the back of the phone using the spudger. There are four clips, one on the left, one on the right, and two on the bottom of the phone.
   crwdns2935267:0crwdne2935267:0Tweezers$4.99
Using tweezers, disconnect the copper ribbon on the left side of the phone by pulling it up from the circuit board.
Remove the antenna by pushing in the tabs on the sides with the spudger, and pulling it out.
Elok tenan Jan sing posting
