Use this repair guide to replace an SD card in a Motorola RAZR2 v9m.
Push the rear cover toward the hinge of the RAZR2. The panel will slide about 3 mm.
Pinch the top and bottom edges of the panel and pull it away from the RAZR2.
Gently pull the white plastic tab to lift the battery away from the RAZR2.
To remove the battery, grasp its edges pull away from the phone.
Press the exposed portion of the SD card towards the bottom of the phone until you hear a click. The SD card will slide into the phone about 10 mm.
Release the SD card. A spring will push it partially out of the phone.
Grasp the card by the edges and remove.
