Use this repair guide to replace a motherboard in a Motorola RAZR2 v9m.
Push the rear cover toward the hinge of the RAZR2. The panel will slide about 3 mm.
Pinch the top and bottom edges of the panel and pull it away from the RAZR2.
Gently pull the white plastic tab to lift the battery away from the RAZR2.
To remove the battery, grasp its edges pull away from the phone.
Gently press the pointy end of the spudger into the edge of the bumper until it bows and separates from the phone.
Grab the bowed portion of bumper. Gently lift and peel the bumper away from the phone.
Remove the two 4-mm T5 Torx screws, previously hidden beneath the flip stop bumper pad.
Close the phone and flip it onto its back.
Remove the two 4-mm T5 Torx screws.
Wedge the spudger about 4 mm into the gap between the phone casing and the rear housing.
Pry the rear housing away from the phone until enough is exposed to grasp with your fingers.
Tilt the loosened half of the rear housing away from the phone. The housing should easily separate after tilting it about 45 degrees away from the phone.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Use a pair of tweezers or your fingers to remove the small rubber cap from the motherboard.
Use a plastic opening tool to gently pry the main motherboard cable connector away from the RAZR2.
Use your finger to bend the connector away from the RAZR2.
Use a spudger to flip open the white clamp holding the keypad ribbon in place.
Slide the tip of a pair of tweezers between the motherboard and the keyboard cable.
Slide the keyboard cable towards the top of the phone, away from the motherboard.
While holding the main motherboard cable connector away from the RAZR2, gently lift the motherboard away from the phone.
